Battery No Good
  • 29 April 2021
  • 1 reply
  • 38 views
I purchased my new Samsung Galaxy S10 phone only 10 months ago and the battery is already no good.  It will not even last a full day and I am hardly using the phone.  Is there warranty for this?  I have never had a battery crap out on me this fast before, it usually does this around the 2 year mark.
Best answer by MilkyWay 29 April 2021, 02:55
Did you purchase it through Koodo? If so, you should be able to get it replaced. Since you purchased it 10 months ago, it should be covered within the one-year warranty period. You can visit a Mobile Klinik location or a Koodo shop to get it repaired. You will have the option to get to use a loaner phone, if available. https://www.koodomobile.com/en/help/warranty-and-repair-policy
In the event that you can’t make it to a Mobile Klinik location or Koodo shop, you can contact the Koodo Web Store by emailing them at koodo.webstore@koodomobile.com and request a return. They will send you an email with further instructions to return your device.
1 reply
