almost understand this, just need a bit more help!
  • 21 August 2015
  • 1 reply
  • 388 views
  • 2 replies
1-so my data usage says 8/100mb but when I click view details, it says page total is 18.30mb....I'm lost....which one is it? (this is for the same bill cycle dates) I'm holding back using data until I understand this better
2-why does it says under my Koodo Mobile 11 unlimited MB box that it is expired? What does that mean?
Psst: what does "Plan OP" mean? what is OP?
Best answer by Camilo_A 21 August 2015, 23:54
Hi there...
Seems like u just signed up to Koodo, welcome!!!
When clients first open the services, they are given 10 days of unlimited data, this period helps to adapt to the data world and avoid overages until your billing cycle resets (Koodo Mobile Mb) ...
So in this moment your real usage should be 18.30mb out of the 100 mb you have...
And OP means , overage protection, you will receive data alerts when you are close to the limits and it will block your data when you reach 100% of the usage Enjoy!!!
1 reply
Hi there...
