Advanced task killer
  • 13 June 2013
  • 7 replies
  • 37 views
With the recent discussions on the Ace being a hot seller and my past of some really low end phones, gotta give praise to this android app: https://play.google.com/store/apps/details?id=com.rechild.advancedtaskkiller Works well and keeps the maching chugging along
Thanks for sharing Geoff
Thanks for sharing GeoffJust being true to the Beavers motto
Thanks for sharing GeoffI uninstalled Task Manager, installed Task Killer, it works like a perl thank you Geoff
Thanks for sharing GeoffLike a perl? Practical Extraction and Report Language? Yes PERL is easy but I believe Task Killer is written Java given the header of the APK. I am not aware of any Android apps written in Perl tho...
I don't think Geoff understands the "praise" aspect of this forum....
The praise section is to be used to give praise to Koodo for things not app developers
Yes and with an ACE 1 or 2, you'll need this app
