Adding data to plan
Can I add data to my plan? Right now I do not have data and wish to add .
If you're on prepaid then you just need to add a data booster.
If you're getting a monthly bill then your plan includes a rate for data use. Check with self serve and your plan details to see what that rate is. It's what you'll pay to use data.
To add monthly data on a monthly plan, you will need to change your plan to a data plan. Koodo doesn't have any one time data add-ons
